Help me solve a slack issue in a circuit
prashanthaditya
Junior Member level 3
Please advice me in solving the below issue
Am using v5fx70 ans ISE 10.1
Thank you for ur time...
Constraint | Check | Worst Case | Best Case | Timing | Timing
| | Slack | Achievable | Errors | Score
* TS_pro_clk = PERIOD TIMEGRP "pro_clk" 7 n | SETUP | -2.246ns| 9.246ns| 46| 52630
s HIGH 50% | HOLD | 0.290ns| | 0| 0
* OFFSET = OUT 6 ns AFTER COMP "pro_clk" | MAXDELAY| -2.035ns| 8.035ns| 37| 50787
* OFFSET = IN 3 ns BEFORE COMP "pro_clk" | SETUP | -1.786ns| 4.786ns| 215| 131749
* TS_phy_clk = PERIOD TIMEGRP "phy_clk" 7 n | SETUP | -0.741ns| 7.741ns| 36| 5894
s HIGH 50% | HOLD | 0.280ns| | 0| 0
* OFFSET = IN 3 ns BEFORE COMP "phy_clk" | SETUP | -0.738ns| 3.738ns| 7| 1798
Re: slack issue..
Did you give proper constraint to your design using sdc file.
Can i see your sdc file that will help.
Shitansh Vaghela
