magdi23
i have got an egauation and i nees to implement it in matlab in both (simulink and m-file, so could you please help me out.
dmM/dt= mM(t)-Rp, the problem here mM(t) which is variable on time, mM max =7.560^-3 when [tm0,tm1]= [30,100 minutes] else mM=0.
actually i havent done the if, else programming and i would somebody to help me also with simulink
thank you and i am looking forward to hearing from you
