implementing SCCB with AXI I2C
aminpix
I am trying to communicate to a Camera module (OV2640). I read many people used I2C instead of SCCB and it works.
I want both read and write into the Camera, however I fail in the first step.
I uses PS of Zynq and my code is:
int main()
    init_platform();
    u8 wdat[2] = {0xFF,0x00};
    XIic *Iic;
    XIic_Config *ConfigPtr;
    ConfigPtr = XIic_LookupConfig(XPAR_IIC_0_DEVICE_ID);
    XIic_CfgInitialize(Iic, ConfigPtr, ConfigPtr->BaseAddress);
    u32 CntlReg = XIic_ReadReg(Iic->BaseAddress, XIIC_CR_REG_OFFSET);
    CntlReg &= ~XIIC_CR_NO_ACK_MASK;
    XIic_WriteReg(Iic->BaseAddress, XIIC_CR_REG_OFFSET, CntlReg);
    XIic_Start(Iic);
    XIic_SetAddress(Iic, XII_ADDR_TO_SEND_TYPE, 0x61);
    XIic_MasterSend(Iic, wdat, 1);
    cleanup_platform();
    return 0;
What I see in the scope is incomplete data sent to the buss:
Any suggestion?
Presumed you are showing the first byte written by the controller, the most obvious point is missing ACK. No meaningful I2C communication can be expected after that. Either wrong address, wiring error or device not ready for communication.
How can I force the PS to ignore the ACK?
I thought this part of code make the PS to disregard ACK:
LaTeX Commands Quick-Menu:
