[AVR] Help me on Atmega32 interface with SHT25 sensor through I2C protocol !!!
zeshan_hyder@hotmail.com
Newbie level 3
hi all,
I am new to micro-controller projects. for my semester project, i want to interface atmega32 with SHT25 tempreture sensor through i2c protocol. i m using proteus ISIS for simulation before implementation.
i want to get tempreture readings from SHT25 and display the readings on portA in binary format. but my circuit and codes are not working and i dont know what is the problem.
code:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
#include <inttypes.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/sleep.h>
#include <util/delay.h>
void i2c_init (void)
    TWSR = 0x00;
    TWBR = 0x47;
    TWCR = 0x04;
void i2c_start (void)
    TWCR = (1<<TWINT) | (1<<TWSTA) | (1<<TWEN);
    while ((TWCR & (1<<TWINT)) == 0);
void i2c_write (unsigned char data)
    TWDR = data;
    TWCR = (1 << TWINT) | (1 << TWEN);
unsigned char i2c_read (unsigned char isLast)
    if (isLast == 0)
    TWCR = (1 << TWINT) | (1 << TWEN) | (1 << TWEA);
    else
    TWCR = (1<<TWINT) | (1<<TWEN);
    while ((TWCR & (1 << TWINT)) == 0);
    return TWDR;
void i2c_stop()
    TWCR = (1 << TWINT) | (1 << TWEN) | (1 << TWSTO);
int main()
unsigned char i = 0;
     DDRA = 0xFF;
     i2c_init();
     i2c_start();
     i2c_write(0b00000101);
     i=i2c_read(1);
     PORTA = 1;
     i2c_stop();
     while(1);
        return 0;
Check this one...
#include <avr/io.h>
    TWSR = 0x00;
    TWBR = 0x47;
    TWCR = 0x04;
    TWDR = data;
    if (isLast == 0)
    else
    return TWDR;
void i2c_stop()
int main()
     DDRA = 0xFF;
     i2c_init();
     i2c_start();
     i=i2c_read(1);
     PORTA = i;
     i2c_stop();
     while(1);
        return 0;
the code, circuit digram and simulation log has been attached with the post. what else you need dear???
ok, probably I did´t clearly gave the point, but once you said that circuit and codes are not working, it is necessary know what debug tests you already performed at each part. This way we can focus attention at the hardware or at the firmware.
I could suggest you try separate each critical routine ( e.g : LCD, I2C, etc... ) in order to individually approve working of each one, because simulating entire program at once become difficult to determine exactly on what point the code fails.
i like your problem finding approach, but what i m trying to do has very simple setup and it couldnt be much more simpler to test the working of each part. you can take a look on my circuit, codes and simulation log to see whats wrong.
it has no lcd, eprom etc.
also take a look at datasheet, if you like to..
zeeshan haider
