Help finding suitable DAC and ADC I2C
jorgealdo
Junior Member level 1
Hello guys (and girls) !!
Pls recommend me a pair of simple DAC and ADC converters, with I2C bus interfacing and no need for external voltage references...
I'm searching for the simplest possible solution but all i find are ones with very complex setups.
Thank you in advance.
LTC1860 is the simplest I2C based ADC I can find. As of DAC, simple I2C solution I don't know but LTC1660 is simple enough if you use SPI.
Hope this helps.
Tahmid.
