Heat sensing circuit with timer and thermistor
vanitapatil
hello sir,
we r doing heat sensing ckt ,,, using thermistor , pleae tel us wt triggering pulse to connect d thermistor..... if u have any heat sensing circuit please give ...
thank u,
Re: heat sensing circuit
Most thermistors are a resistor that has been specially made to change its value with temperature. The normal way of using them is to feed the thermistor by a high value resistor from a DC supply (high value resistor= low current, so keeps thermistor cool) and measuring the voltage drop across it. - no pulses.
Frank
Also note that
"Thermistors can be classified into two types, depending on the sign of k. If k is positive, the resistance increases with increasing temperature, and the device is called a positive temperature coefficient (PTC) thermistor, or posistor. If k is negative, the resistance decreases with increasing temperature, and the device is called a negative temperature coefficient (NTC) thermistor."
Thermistor - Wikipedia, the free encyclopedia
Alex
sir ,if possible send one heat sensing circuit using 555 timer and thermistor
