wf1318
Hello!
Please take a look on the following picture first.
Recently I had build 2 of this amp circuit for my family's PC as a headphone amp.
This little amp work OK when connected to headphone.
After that I have an idea is that I want to use the amp headphone jack output as a line out to drive a 3W cheap power amp,
just want to see what kind of sound will come out.
However there is no sound come out.
Therefore I check the circuit again, and then I connected it back to the headphone, and it work fine without any problem.
I don't know what happen, why it works fine with a headphone but not OK as a line out.
After that, I connect these 2 amp circuit as the following setup just want to find out what the is problem:
I use a Headphone Jack Splitter connected to Amplifier 1,
and then this Headphone Jack Splitter is conneced to a headphone and also a audio cable is connected to Amplifier 2.
As the result there is no sound come out from the Headphone.
However, when I unplugged the audio cable, the sound is back to the headphone!
So, what is the problem with this amp?
Can I add / modify the component that I can make this amp can connect to other power amp?
Oh, sorry for my poor english....
Anyway, thank you.
Anyway, thank you.
