Harmonics Elimination output sine wave of DC-AC converter
asimraufawan
Hi everyone,
Kindly let me know what hardware design should i use to eliminate harmonics
from the attached AC waveform.
It is the filtered output AC sine wave of a static converter.
Re: Harmonics Elimination output sine wave of DC-AC converte
What kind of output filter are you using? I am designing a similar system, take a look at my results here:
I get not very nice sine waveform at the peak of the output voltage. But I have been told it might be due to the measurement technique. I really do not know for sure.
first off all the sine wave is a modified sine wave using step square wave not the PWM , the output AC volt is than connected to the 230VAC capacitors for filteration as shown in diagram.
Can you show the unfiltered waveforms? What is the switching frequency of your step square signal?
attached is the unfiltered waveform.
reduce amplification. I guess you see pulses on resonant-frequency of you filter
how will i reduce amplification
