StoppTidigare
Full Member level 2
- Joined
- Jul 16, 2002
- Messages
- 148
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,296
- Location
- Northern earth
- Activity points
- 1,703
Hi, could somebody help me with these questions of mine:
1.Should a gunn-diode be forward or back biased to start to oscillate.
2. If I feed a dipole antenna with an unbalanced 75 Ohm coax, what happens ? Does the current distribution change ?If so why ? Why should I use a balun ?
3.I have acess to a X-band experimental waveguide lab set-up, there you can modulate the 10GHz carrier(gunn-diode) with a 1kHz square-wave. Why did the designers of the labsystem choose to allow the experimenter to modulate the carrier with 1kHz ? Is it for a more accurate meausrment of some parameter ?
4.Does somebody have a nice timediagram over the Gilbert mixer, (when diodes are on/off) as a function of the input signals ?
Regards,
StoppTidigare
A message to Odysseus: Couldn't you make your tutorials with a tool that is free availible , pleeeaaase ?(Like APLAC )
Regards,
StoppTidigare
