GSM Module, GPRS conncetion through AT Commands problem
pappu_sam
HYDERABAD
Hi all,
I am using SIM300 GSM Module,
trying to configure GPRS through AT Commands like this
>>AT
<<OK
>>AT+CGATT=1
<<OK
>>AT+CGDCONT=1,"IP","airtelgprs.com",0,0
<<OK
>>AT+CDNSCFG="0.0.0.0","0.0.0.0"
<<OK
>>AT+CSTT="airtelgprs.com","",""
<<OK
>>AT+CIICR
<<OK
>>AT+CIFSR
<<Getting some IP and OK
>>AT+CIPSTATUS
<<OK and STATUS: IP STATUS
>>AT+CIPHEAD=1
<<OK
>>AT+CDNSORIP=0   // am giving my IP address to connect
<<OK
>>AT+CIPSTART="TCP","61.12.35.117","80"
<<OK
<<CONNECT OK
>>AT+CIPSEND
<< > it is promting to receive data
[SIZE=4]when I give data it is hanging up and after some time am getting reply as[/SIZE]
<<CLOSED
please suggest me how to receive data from my server
CIPSEND is to send data from module to server ip and port
there is no need of any at command to recv data from server in GPRS mode
Hi akvii,
am not sending AT commands after CIPSEND
am sending GET/HTTP/1.1 Host: www.google.com Connection: Keep-Alive
nothing am receiving from server
after 3 minutes its giving response as CLOSED...
hi
module automatically disconnects from GPRS when there is no activity for 3 or more m
two files are attached....portpeeker is to make your pc/laptop server...if you are using router or switch then you have forward a port in it....if your machine is directly connected to the internet then skip that step
client is to send data to the specfic ip and port....you can use two PCs instead of module for understanding the procedure
  • TCP Client.rar
  • PortPeeker.exe
hi akvii,
Thanx for ur suggestion .... its working between two pcs.
but how to connect through GSM module using AT commands
1: "AT+CMGF=1",13
module respond "OK"
2: "AT+CIPSTART=",34,"TCP",34,",",34,"ip of server",34,",",34,"port",34,13]
module respond "CONNECT OK"
3: "AT+CIPSEND",13
WAIT FOR ">" THEN SEND/type ANY DATA
open portpeeker and configure it as your requirement in your PC....now this is your server....enter its IP and port in step2...you will see all the activity in it
if you want to receive data in GPRS module then use TCPclient and send data
