gsm modem sim900 problem
Noman Yousaf
Full Member level 4
Lahore Pakistan
hi all
i have been using gsm modem SIM300DZ only for sending or receiving the sms's. now i want to use SIM900 intead of SIM300. can u tell what i have to do more? or these are same for such purpose. what are the diffrences between both modems?
please reply soon
---------- Post added at 16:04 ---------- Previous post was at 16:03 ----------
and from where, i can get the datasheet of SIM900?
Hi Noman Apart from the voltages on the I/O, the main and most annoying difference is that the sim 900 only accepts AT commands in upper case. I have attached a couple of file which may be of use.
  • SIM900D_SIM300D340D_HD_Comparison_V1.02.pdf
  • SIM900_Sim300_ATC_Comparison_V1.01.pdf
  • SIM900_Specification_V1102.pdf
Here are the files uploaded again. If you still cannot download them IM me with your e-mail address so I can send them directly
  • SIM900D_SIM300D&340D_Comparison_Hardware Design_V1.03.pdf
  • SIM900D_Specification_V1102.pdf
  • SIM900_Hardware Design_V2.00.pdf
This is not true. I have SIM900 and it accepts at commands in both upper and lower case.
Regards.
Salman.
