ballimo
Member level 3
ground plane connections
Hi All,
I have a board with 8 internal ground layers(Planes), I have some through hole connector, and I 'am using Allegro PCB editor; by default a ground through hole pad will connect to all the 8 internal ground layer.
I want to connect each through hole ground pad to a maximum of 3 ground planes, did anyone know how I can do it? (because if ground pad will connect to 8 planes I will have a problem during the soldering process.)
Thanks for your help...
Ballimo
Hi All,
Ballimo
