kaiserschmarren87
Member level 4
Hallo,
I have to pass a (6 downto 0) value (it is an output as std_logic_vector) from my top module to one of the sub module(as Generic). Is there any work around for this? (I know that an integer value contained in a signal can't be mapped to a generic variable.
To explain it clearly:
Top module has ------------ sample(6 downto 0);
--Instantiated module ----- count <= to_integer(signed(sample));
----sub_module(pb_debounce shown below) ----------- it has a generic variable named counter which needs the count value to be passed to it since this value comes from configurable memory and it can vary.
I use a similar code:
I need the shift register to be dependent on varying value of count which is captured from the top module.
I hope the question is clear.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 entity pb_debounce is generic(count : integer) port(----in/out ports) ); entity pb_debounce; architecture behavioral of pb_debounce is signal SHIFT_PB : std_logic_vector(count-1 downto 0); begin process begin if rising_edge(clock) then --You're clock SHIFT_PB(count-2 Downto 0) <= SHIFT_PB(count-1 Downto 1); --Shifting each cycle SHIFT_PB(count-1) <= NOT PB; --PB is the pre-bounced signal If SHIFT_PB(count-1 Downto 0)="0000" THEN --once the bounce has settled set the debounced value PB_DEBOUNCED <= '1'; ELSE PB_DEBOUNCED <= '0'; End if; end process; end behavioral;
