namename
Newbie
as title when i input 1 it's just stop
this is my code
this is my code
test/birthday_ex.v at main · Taiwanisnotchina/test
Contribute to Taiwanisnotchina/test development by creating an account on GitHub.
github.com
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 module seven_seg_cnt0_7( clk, rst, CA, CB, CC, CD, CE, CF, CG, AN0, AN1, AN2, AN3, AN4, AN5, AN6, AN7 ); input clk; input rst; output CA,CB,CC,CD,CE,CF,CG; output AN0,AN1,AN2,AN3,AN4,AN5,AN6,AN7; reg [2:0] cnt; reg [6:0] seg_number,seg_data; reg [31:0] cnt_2hz; reg clk_2hz; wire [3:0] birth_num; assign {AN7,AN6,AN5,AN4,AN3,AN2,AN1,AN0} = 8'b1111_1110; //turn on the 8th 7seg LED assign {CG,CF,CE,CD,CC,CB,CA} = seg_data; //**CLK_DIV**// always@ (posedge clk or posedge rst) begin if (rst) begin cnt_2hz <= 32'b0; clk_2hz <= 1'b0; end else begin if (cnt_2hz >= 25000000) begin cnt_2hz <= 32'b0; clk_2hz <= ~clk_2hz; end else begin cnt_2hz <= cnt_2hz + 1; clk_2hz <= clk_2hz; end end end //**COUNTER**// always@ (posedge clk_2hz ) begin if (rst)begin cnt <= cnt + 3'b1; end else begin cnt <= cnt + 3'b1; end end assign birth_num[3] = (!cnt[2] & !cnt[1] & cnt[0]) | (cnt[2] & cnt[1] & cnt[0]); assign birth_num[2] = !cnt[2] & cnt[1]; assign birth_num[1] = (!cnt[2] & cnt[1]) | (cnt[2] & !cnt[1] & cnt[0]); assign birth_num[0] = (!cnt[2] & !cnt[1]) | (cnt[2] & cnt[0]) | (cnt[1] & !cnt[0]); //**BCD_to_7seg**// always@(*) begin if (~rst) begin seg_data[0] = (cnt[2] & !cnt[1] & !cnt[0]) | (!cnt[2] & !cnt[1] & cnt[0]); //CA seg_data[1] = (cnt[2] & !cnt[1] & cnt[0]) | (cnt[2] & cnt[1] & !cnt[0]); //CB seg_data[2] = !cnt[2] & cnt[1] & !cnt[0]; //CC seg_data[3] = (cnt[2] & !cnt[1] & !cnt[0]) | (!cnt[2] & !cnt[1] & cnt[0]) | (cnt[2] & cnt[1] & cnt[0]); //CD seg_data[4] = (cnt[2] & !cnt[1]) | (!cnt[2] & cnt[0]) | (cnt[2] & cnt[0]); //CE seg_data[5] = (!cnt[2] & cnt[0]) | (!cnt[2] & cnt[1]); //CF seg_data[6] = (!cnt[2] & !cnt[1]) | (cnt[2] & cnt[1] & cnt[0]) ; //CG end else begin seg_data[6] = (!birth_num[3] & !birth_num[2] & !birth_num[1]) | (!birth_num[3] & birth_num[2] & birth_num[1] & birth_num[0]); seg_data[5] = (!birth_num[3] & !birth_num[2] & birth_num[0]) | (!birth_num[3] & !birth_num[2] & birth_num[1]); seg_data[4] = (!birth_num[3] & birth_num[2] & !birth_num[1]) | (!birth_num[2] & !birth_num[1] & birth_num[0]) | (!birth_num[3] & birth_num[2] & birth_num[0]) | (!birth_num[3] & birth_num[1] & birth_num[0]); seg_data[3] = (!birth_num[3] & birth_num[2] & !birth_num[1] & !birth_num[0]) | (!birth_num[3] & !birth_num[2] & !birth_num[1] & birth_num[0]) | (!birth_num[3] & birth_num[2] & birth_num[1] & birth_num[0]); seg_data[2] = (!birth_num[3] & !birth_num[2] & birth_num[1] & !birth_num[0]); seg_data[1] = (!birth_num[3] & birth_num[2] & !birth_num[1] & birth_num[0]) | (!birth_num[3] & birth_num[2] & birth_num[1] & !birth_num[0]); seg_data[0] = (!birth_num[3] & birth_num[2] & !birth_num[1] & !birth_num[0]) | (!birth_num[3] & !birth_num[2] & !birth_num[1] & birth_num[0]); end end endmodule
