ElectroEnthusiast
Member level 5
I wanted to sketch a circuit diagram, the ic used was icl 7107 for which i didn't get the library file/component on eagle. So, i continued drawing the schematic using a 40 pin DIP package. The problem is the component seems to be too small. I've posted the image, i was unable to clearly draw the circuit diagram. The problem is indicated in the image. Everything gets crammed. Any suggestions to get rid of this? Also, is it possible to change the dimensions of the IC? Thanks in Advance
