promach
I have problem with file read permission error inside Vivado, but it seems that none of the actual mentioned files had file read permission issues. I have attached the entire Vivado project as a compressed zip file.
Could anyone advise ?
See the console log : the path is not long, and there is no whitespace in the path, and the path is not empty string ""
test_ddr3_memory_controller.mem.cmd_task: at time 701958671.0 ps INFO: Initialization Sequence is complete
test_ddr3_memory_controller.mem.cmd_task: at time 703430100.0 ps INFO: Precharge All
test_ddr3_memory_controller.mem.cmd_task: at time 703432957.0 ps INFO: Precharge All
test_ddr3_memory_controller.mem.cmd_task: at time 703435814.0 ps INFO: Precharge All
test_ddr3_memory_controller.mem.cmd_task: at time 703438671.0 ps INFO: Precharge All
test_ddr3_memory_controller.mem.cmd_task: at time 703441528.0 ps INFO: Precharge All
test_ddr3_memory_controller.mem.cmd_task: at time 703444385.0 ps INFO: Load Mode 3
test_ddr3_memory_controller.mem.cmd_task: at time 703444385.0 ps INFO: Load Mode 3 MultiPurpose Register Select = Pre-defined pattern
test_ddr3_memory_controller.mem.cmd_task: at time 703444385.0 ps INFO: Load Mode 3 MultiPurpose Register Enable = Enabled
test_ddr3_memory_controller.mem.cmd_task: at time 703501528.0 ps INFO: Read bank 3 col 000, auto precharge 1
test_ddr3_memory_controller.mem.read_from_file: at time 703514385.0 ps ERROR: fseek to x failed
$finish called at time : 703514385 ps : File "/home/phung/Downloads/DDR_backup/DDR_Xilinx_Vivado/DDR_Xilinx_Vivado.srcs/sources_1/imports/DDR/ddr3.v" Line 665
run: Time (s): cpu = 00:00:52 ; elapsed = 00:11:37 . Memory (MB): peak = 7663.180 ; gain = 2.137 ; free physical = 3865 ; free virtual = 10404
