abhishek.2138
Full Member level 2
I am using power management IC (PMIC) for 32 bit microcontroller (MCU).
The IC has internal synchronous buck converter & two LDOs.
One of the LDO is used for microcontroller supply.
I have following queries.
1) Should I use ferrite bead? does ferrite bead help here to filter noise from (PMIC) to MCU?
2) To use ferrite bead, where should I place it? near to microcontroller Vdd pins or at the LDO output (here LDO is internal of PMIC)?
