exponent turns field into zero amplitude
yefj
Hello,bellow we can see the field lines and its formula's.
for x=a/2 and z=lambda/4 we suppose to get Ex=0 Ez=Max
from E_x the cosine is zero
but E_z is zero also because the exponent will give us complex "j"
in both Ex and Ez there are exponent expressions with z variable.
How mathematickly this exponent can cause the whole expression to be zero?(as shown in the field lines bellow)
Thanks.
Ex and Ez depend on sin and cos functions
for Ex, cos = 0 when pi/a *x = pi/2, 3pi/2, 5pi/2, etc
for Ez, sin = 0 when pi/a * z = 0, pi, 2pi, 3pi, etc
at x=a/2, pi/a * x = pi/a * a/2 = pi/2 so cos =0
at x = a, pi/a * x = pi/a * a = pi, so sin =0
as for "at z=lambda/4 we suppose to get Ex=0 Ez=Max ",
look at euler's formula
e^i x = cos ⁡ x + i sin ⁡ x
exponent can be zero only at minus infinity.
our complex exponent has absolute vale of 1 at every value
how exactly its zero?
the zeros you are seeing in your field diagram in first post
are due to sin and cos, not due to the exponent
euler's formula e^i x = cos ⁡ x + i sin ⁡ x
has a real part, cos, and an imaginary part, sin
if x = - infinity, e^(-j*infinity) is NOT the same as e^(-infinity)
e^(-j*infinity) = cos ⁡ (-infinity) + i sin ⁡(-infinity) is not necessarily zero
whereas
e^(-infinity) = 0 is necessarily zero
yes so how exactly a complex exponent can be zero
there is no suc value
