Expand the I/O pins of PIC16F877A
nooobboy4321
Junior Member level 1
Hello, I just want to know how or is possible to expand the I/O pins of PIC16F877A? I need 126 I/O pins.
Thanks.
Existing EDABoard forum threads :
How to expand the I/Os of PIC microcontroller?
https://www.edaboard.com/threads/111969/
Did you consider to use some bus technology like 1-Wire or CAN ?
Interfacing The MCP23016 I/O Expander With The PIC16F877A
You can get up to 128 I/O. See attachment.
  • microchipc_an245_mcp23016.pdf
Are those 126 must have both Input and output capabilities ?
If you can divide them as input only and output, that make things little easier.
Hello DineshSL, I need some help in using PIC16F877A-SPI-MCP23S17.... About what you said at your reply, YES, I'm planning to use MCP23S17 as a regular PORT like PORTA and other PORTS that can use either INPUT/OUTPUT in PIC16F877A... Can you give at least a Sample Code in C about Setting Up PIC16F877A SPI to MCP23S17 and setting Up MCP23S17 as Regular PORTS Input and Output like TRIS Registers of PORTA as Input... TRISA = 0xFF;.... Btw I'm using Proteus and Mikro C.... Please Help me... Thanks
If you know how to program SPI module of PIC in MicroC, that all. You can use CS pin of MCP23S17 to direct your SPI data to a particular MSP23S17.
How to select pins as Input or out-put, how to write/read data to them are explained in datasheet of MCP23S17.
Check following for Microchip sample project;
