ADR_1
Newbie level 2
Hello,
I have a controller (LCD, processor, PSU, with encoders and a joystick) in an aluminum enclosure that occasionally experiences malfunctions due to ESD events. Through some basic testing in the lab, I have found that connecting the enclosure to an earth ground using a 50cm long ground strap significantly improves the controller's resistance to malfunctions caused by ESD events.
I have tested using a 10AWG flat braided strap and a regular stranded insulated 10AWG hookup wire and did not observe any difference.
Is the braided ground strap or wire strap recommended?
I'm tending more towards the braided strap since with ESD events the rise time is on the order of nano seconds, which could result in the skin effect becoming significant, but I'm not sure.
Any direction or advice would be much appreciated. Thanks!
