Error when launching PCB Navigator
manishyamdagni
Junior Member level 2
About PCB Navigator
Hello All Friends,
I have a problem with PCB Navigator after installation when I try to start it, it will give a error message THE APPLICATION FAILED TO INTIALISE PROPERLY as seen in attached file.
Please help to get out of this error, Thanks in advance.
About PCB Navigator
Perhaps license conflict
About PCB Navigator
Try reinstalling the navigator.
which version of the navigator you use ?
binu g
Re: About PCB Navigator
I've installed version 3, I think it is freeware so there shouldn't be license problems
manish
About PCB Navigator
version 3 is not the primary problem. it also depend on the host tools you are using.
for example if u try to use the nav3 for orcad10 or above it will not work. so better confirm the same.
else specify the tools you want to interlink.
Use PCB Navigator V5 for Orcad 10.xx but I also install PCB Navigator 4.01 on Orcad 10, it also run, but the feature of PCB Navigator can't run on menu of Orcad 10.
Good luck
