error on VHDL program....
energy_baz
Junior Member level 1
hi,
could anyone help me to fix this error...the error state : Found 0 definitions for operator "+"...thanks :)
wire1(n) is a std_logic. wire1(n downto n) is a 1 bit unsigned value. "+" is not defined for unsigned+std_logic, but for unsigned+unsigned (and unsigned+integer).
so, I have to convert wire1(n) into unsigned/integer is it..?
try using wire1(n downto n) for a 1 bit unsigned array, and it should work.
