Gayathrirani
I am trying to implement a LED blinking program using EDK.I have selected GPIO LEDs(datawidth 8) and updated UCF files.When i try to launch it on hardware ,the error "MicroBlaze is under reset.Check if the reset input to MicroBlaze and its Bus interfaces are connected prpoerly" appears.I am using Genesys Virtex-5 board and for reset input i am using a push button(G7) since there's no LOC for reset given in the .ucf.
I get the warning message also in EDK.
"WARNINGar:288 - The signal dlmb_LMB_ABus<30> has no load. PAR will not attempt to route this signal.
WARNINGar:288 - The signal dlmb_LMB_ABus<31> has no load. PAR will not attempt to route this signal."
How to solve this issue?
