I don't know if I really understand what you are trying to say but if you are asking what is the n/p epi's function in your stated stack up, for an npn transistor, the n-epi will serve as the collector region of the device. For a substrate vertical pnp and a lateral pnp, the n-epi will serve as the base region of the device. When the epi region is p-epi, this can be channel for an nmosfet, it can be part of a junction capacitors/diodes, or an isolation ring if the p-epi is doped heavy.suppose is p-sub, n/p-epi in bipolar and bicmos function.
