Effect of noise on Power Spectral Density
ipmax
Newbie level 5
Hi all,
How does noise affect the PSD of a received signal.
y = x + n
PSD(y) = PSD(x) + PSD(n)
So, the PSD of received signal is higher in all frequencies as compared to the transmitted signal.
So, if my understanding is correct, if at a particular frequency PSD(x) = -10 dB and white noise PSD = -25dB, the received signal will have PSD of -35 dB at that frequency. Is this understanding correct?
Thanks,
Max
The signal represention
y=x+n
refers to linear quantities (e.g.: Watt). Then if you have the PSD in dBm you have to conver it first to linear.
in your example:
PSD(x) = -10 dBm/Hz --> 10exp(-4) W/Hz
PSD(n) = -25 dBm/Hz --> 3.2exp(-6) W/Hz
PSD(y) = 10*Log[10exp(-4)+3.2exp(-6)]+30 = -9.86 dBm/Hz
Perfectly makes sense !! Thanks
