eeprom store data should be display on lcd...pls tel my mistake..?
jaya krishna
Member level 1
India,coimbatore
hi every one, i doing eeprom program, some data is write in eeprom and also same data is read and display on lcd...my code is run correctly but in schematic lcd show nothing... pls where i done my mistake in my code...
PHP:
#include <16F877a.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#use i2c(MASTER, FAST, SCL=PIN_C3, SDA=PIN_C4, FORCE_HW)
#define EEPROM_SDA  PIN_C4
#define EEPROM_SCL  PIN_C3
#include <24256.c>
#define rs PIN_C0
#define rw PIN_C1
#define en PIN_C2
 void lcdcmd(unsigned char cmd);
 void lcddata(unsigned long int volt);
char const line1[]= {"Hello World"};
void main()
    int8 i;
    int buffer[17];
    set_tris_b(0x00);
    lcdcmd(0x38);
    lcdcmd(0x0E);
    lcdcmd(0x01);
    lcdcmd(0x06);
    lcdcmd(0x80);
//while(1)
// Write "Hello World" to external eeprom chip.
for(i = 0; i < sizeof(line1); i++)
    write_ext_eeprom(i, line1[i]);
// Read characters from the external eeprom chip
// and write them into a RAM buffer.
    buffer[i] = read_ext_eeprom(i);
    //bufferr = buffer[i];
 lcddata(buffer[i]);
// Display the message on the LCD.
//printf(lcd_putc, buffer);
while(1);
  output_b(cmd);
  output_low(rs);
  output_low(rw);
  output_high(en);
  delay_ms(1);
  output_low(en);
  output_b(volt);
  output_high(rs);
  output_low(rw);
  output_high(en);
  delay_ms(1);
  output_low(en);
my Proteus schematic attached
