EAGLE Layout Library Files for
ElectroEnthusiast
Member level 5
Member level 5
Hi, i wanted a Eagle library files for various components. The components are listed below.
Please tell me where i can get them or provide me the link or attach the file.
1) Receptacle / Bulb Holder
2) 1:1 Transformer
3) What should i use to denote mains voltage? (or what is pointed box-type component called)?
4) Fuse 6A
5) Big Switch
Thanks
If the components you want are not in the standard libraries you could try looking on the Eagle website for a library download. If that doesn't get you what you want then you could try the Farnell website as they are now providing Eagle parts for some components. If all else fails you could always make you own library parts, do it once an you'll find it's really easy.
what is that component called? the one which is used to denote mains voltage inlets? (signal library?)
You are going to have to give more info, do you have a picture?
