Dynamic Phase Shift issue for spartan-6
promach
I enabled Dynamic Phase Shift Ports inside ISE clocking wizard coregen, however I have the following issues about unsupported frequencies marked as XXX in the table:
100MHz, 200MHz, 300MHz, 400MHz, 500MHz are all not supported when Dynamic Phase Shift is enabled.
Note: I am using 50MHz source clock
Just a matter of limited Xilinx series 6 clocking features. If you read the documentation thoroughly, you'll notice that dynamic phase shift and clock multiplication (DFS) are mutual exclusive DCM options.
    promach
if you can use two DCM one for clock multiplication and other for dynamic phase shifting .... since the Dynamic phase shifting is using delay TAPS ...it's not a part of clock multiplication circuitry ....as shown above...
    promach
@bansalr
DCM IP is not available to spartan-6, do you mean two PLL IP instead ?
As for "Dynamic phase shifting is using delay TAPS", do you mean I should use separate IODELAY primitive instead of PLL ?
yes, If you can use two PLL IP instead ... No I am explaining how dynamic phase shift works using delay inside the IP...
    promach
