aguijon
Hi all,
I need some help about antenna impedance matching. I have a design with a dual band antenna which is fed by the output of a power amplifier. and from amplifier output
to antenna there are pads for 3 series elements and for two shunt elements. Also path from the power amplifer output to antenna is a little bit long. I want to match this antenna
using lumped elements. So, first of all i measured S11 parameter of the antenna itself by soldering a coaxial cable just in the entrance of the antenna.(Also i disconnect the rest of the circuit that lies behind this coaxila cable)
Then by considering the output of PA as 50 ohm, i tried to design a matching network in AWR Microwave office. I modeled the antenna as a subcircuit in AWR with data file that is exported from our network analyzer. But the problem here is for example i am adding an inductor in AWR to achieve a better S11 result but i cannot see the same effect of this componenet
in reality. Although i am taking into account SRF and tolerance of components, i cannot have a correlation between simulation results and real measurements. I am not sure but i think length of path and presence of discontinuties in components pads effect the matching drastically.
In this point, I am just wondering that if I am performing matching right? If not what is the correct methodology to perform a dual band matching with lumped elements? If I run a EM simulation in AWR can i obtain more realistic results?
Thanks.
Javier.
Thanks.
Javier.
