Reychard
- Joined
- Oct 9, 2010
- Messages
- 6
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- McMurdo Station
- Activity points
- 1,324
Hi everyone,
I'm using the DS18B20 one-wire digital sensor on the FX2-BB connected to my Spartan-3 board.
I've found some code online and spent some time understanding what's going on.
The code is over here courtesy of codeforge:
Now, when I compile it, I get the following two warnings:
I understand that the constant value is due to an undriven input. But what write_temp essentially does is contain the code for performing operations such as convert temperature, read ROM, etc.
Because of these two warnings, I am unable to get any values because the values read from the sensors depend on these two very much.
Could anyone with some experience on using the DS18B20 or VHDL please help me out with this?
Kind regards,
Rey
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity ds1820 is
port(clk : in std_logic;
dq : inout std_logic;
temp_h : out std_logic_vector(7 downto 0);
temp_l : out std_logic_vector(7 downto 0));
end ds1820;
architecture Behavioral of ds1820 is
TYPE STATE_TYPE is (RESET,CMD_CC,WRITE_BYTE,WRITE_LOW,WRITE_HIGH,READ_BIT,CMD_44,WAIT800MS,CMD_BE,GET_TMP,WAIT4MS);
signal STATE: STATE_TYPE:=RESET;
signal clk_temp : std_logic:='0';
signal clk1m : std_logic;
signal write_temp : std_logic_vector(7 downto 0):="00000000";
signal TMP : std_logic_vector(11 downto 0);
signal tmp_bit : std_logic;
signal WRITE_BYTE_CNT : integer range 0 to 8:=0;
signal WRITE_LOW_CNT : integer range 0 to 2:=0;
signal WRITE_HIGH_CNT : integer range 0 to 2:=0;
signal READ_BIT_CNT : integer range 0 to 3:=0;
signal GET_TMP_CNT : integer range 0 to 12:=0;
signal cnt : integer range 0 to 100001:=0;
signal count : integer range 0 to 25:=0;
signal WRITE_BYTE_FLAG : integer range 0 to 4:=0;
begin
ClkDivider:process (clk)
begin
if rising_edge(clk) then
if (count = 24) then
count <= 0;
clk_temp<= not clk_temp;
else
count <= count +1;
end if;
end if;
clk1m<=clk_temp;
end Process;
STATE_TRANSITION:process(STATE,clk1m)
begin
if rising_edge(clk1m) then
case STATE is
when RESET=>
if (cnt>=0 and cnt<500) then
dq<='0';
cnt<=cnt+1;
STATE<=RESET;
elsif (cnt>=500 and cnt<1000) then
dq<='Z';
cnt<=cnt+1;
STATE<=RESET;
elsif (cnt>=1000) then
cnt<=0;
STATE<=CMD_CC;
end if;
when CMD_CC=>
write_temp<="11001100";
STATE<=WRITE_BYTE;
when WRITE_BYTE=>
case WRITE_BYTE_CNT is
when 0 to 7=>
if (write_temp(WRITE_BYTE_CNT)='0') then
STATE<=WRITE_LOW;
else
STATE<=WRITE_HIGH;
end if;
WRITE_BYTE_CNT<=WRITE_BYTE_CNT+1;
when 8=>
if (WRITE_BYTE_FLAG=0) then -- 第一次写0XCC完毕
STATE<=CMD_44;
WRITE_BYTE_FLAG<=1;
elsif (WRITE_BYTE_FLAG=1) then --写0X44完毕
STATE<=RESET;
WRITE_BYTE_FLAG<=2;
elsif (WRITE_BYTE_FLAG=2) then --第二次写0XCC完毕
STATE<=CMD_BE;
WRITE_BYTE_FLAG<=3;
elsif (WRITE_BYTE_FLAG=3) then --写0XBE完毕
STATE<=GET_TMP;
WRITE_BYTE_FLAG<=0;
end if;
WRITE_BYTE_CNT<=0;
end case;
when WRITE_LOW=>
case WRITE_LOW_CNT is
when 0=>
dq<='0';
if (cnt=78) then
cnt<=0;
WRITE_LOW_CNT<=1;
else
cnt<=cnt+1;
end if;
when 1=>
dq<='Z';
if (cnt=2) then
cnt<=0;
WRITE_LOW_CNT<=2;
else
cnt<=cnt+1;
end if;
when 2=>
STATE<=WRITE_BYTE;
WRITE_LOW_CNT<=0;
when others=>WRITE_LOW_CNT<=0;
end case;
when WRITE_HIGH=>
case WRITE_HIGH_CNT is
when 0=>
dq<='0';
if (cnt=8) then
cnt<=0;
WRITE_HIGH_CNT<=1;
else
cnt<=cnt+1;
end if;
when 1=>
dq<='Z';
if (cnt=72) then
cnt<=0;
WRITE_HIGH_CNT<=2;
else
cnt<=cnt+1;
end if;
when 2=>
STATE<=WRITE_BYTE;
WRITE_HIGH_CNT<=0;
when others=>WRITE_HIGH_CNT<=0;
end case;
when READ_BIT=>
case READ_BIT_CNT is
when 0=>
dq<='0';
if (cnt=4) then
READ_BIT_CNT<=1;
cnt<=0;
else
cnt<=cnt+1;
end if;
when 1=>
dq<='Z';
if (cnt=4) then
READ_BIT_CNT<=2;
cnt<=0;
else
cnt<=cnt+1;
end if;
when 2=>
TMP_BIT<=dq;
if (cnt=1) then
READ_BIT_CNT<=3;
cnt<=0;
else
cnt<=cnt+1;
end if;
when 3=>
if (cnt=45) then
cnt<=0;
READ_BIT_CNT<=0;
STATE<=GET_TMP;
else
cnt<=cnt+1;
end if;
when others=>READ_BIT_CNT<=0;
end case;
when CMD_44=>
write_temp<="01000100";
STATE<=WRITE_BYTE;
when WAIT800MS=>
if (cnt>=100000) then
STATE<=RESET;
cnt<=0;
else
cnt<=cnt+1;
STATE<=WAIT800MS;
end if;
when CMD_BE=>
write_temp<="10111110";
STATE<=WRITE_BYTE;
when GET_TMP=>
case GET_TMP_CNT is
when 0 to 11=>
STATE<=READ_BIT;
TMP(GET_TMP_CNT)<=TMP_BIT;
GET_TMP_CNT<=GET_TMP_CNT+1;
when 12=>
GET_TMP_CNT<=0;
STATE<=WAIT4MS;
end case;
when WAIT4MS=>
if (cnt>=4000) then
STATE<=RESET;
cnt<=0;
else
cnt<=cnt+1;
STATE<=WAIT4MS;
end if;
when others=>STATE<=RESET;
end case;
end if;
end process;
temp_h<='0'&TMP(11 downto 5);
temp_l<="0000"&TMP(4 downto 1);
end Behavioral;
WARNING:Xst:1293 - FF/Latch <write_temp_0> has a constant value of 0 in block <ds18b20>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <Mtridata_dq> (without init value) has a constant value of 0 in block <ds18b20>. This FF/Latch will be trimmed during the optimization process
Kind regards,
Rey
