Dim Temp As Byte
Dim Temp1 As Byte
Dim TimeData[6] As Byte
Dim OldSeconds As Byte
Dim Seconds As timedata#0
Dim Minutes As timedata#1
Dim Hours As timedata#2
Dim Date As timedata#3
Dim Month As timedata#4
Dim Year As timedata#5
'Define registers
Symbol SECREG = %00000
Symbol MINREG = %00001
Symbol HRSREG = %00010
Symbol DATEREG = %00011
Symbol MONREG = %00100
Symbol YRREG = %00110
Symbol CTRLREG = %00111
Symbol BRSTREG = %11111
Symbol CLK = PORTC.3
Symbol DTA = PORTC.4
Symbol RST = PORTC.2
' Time setup data held in eeprom memory
PRST EData $59,$59,$23,$31,$03,$10,$10
All_Digital = True
Print At 1,1,"asdasd"
DelayMS 2000
Cls
' Clear Write Protect bit in control register of DS1302
Temp = $10
RTCcmd = CTRLREG
GoSub DS1302_WRITE
' Pre-set the time registers using a data table stored in eeprom memory
For Temp1 = 0 To 6
Temp = ERead PRST + Temp1
RTCcmd = Temp1
GoSub DS1302_WRITE
Next
Temp = $80
RTCcmd = CTRLREG
GoSub DS1302_READ
'Only Displays on the LCD if the seconds have changed
While 1 = 1
GoSub DS1302_READ
If OldSeconds <> Seconds Then
Print At 1,1, "TIME ", Hex2 Hours,":",Hex2 Minutes,":",Hex2 Seconds
Print At 2,1, "DATE ", Hex2 Date,"/",Hex2 Month,"/",Hex2 Year
EndIf
Wend
' Write to DS1302 RTC
DS1302_WRITE:
High RST
SHOut DTA, CLK, LsbFirst, [%0\1,RTCcmd\5,%10\2,Temp\8]
Low RST
Return
' Read from the DS1302
DS1302_READ:
High RST
SHOut DTA, CLK, LsbFirst, [%111111\6,%10\2]
OldSeconds = Seconds
SHIn DTA, CLK, LsbPre, [Seconds,Minutes,Hours,Date,Month,Year,Year]
Low RST
Return
