rhnrgn
Member level 5
Hello Friends,
I am going to make a PCB board which is going to drive 16 DC Motors in 2 direction.
I made a simple drawing with 5 mosfets and 1 not gate.
I want to ask you is there any simple IC component which is going to drive at least 2 motors. Simple means i need only 50ma for 1 motor. That is why, component should be small, should only has 1 enable 1 dır and 2 motor cable input pin for 1 motor and 1 power input (24V maximum). (I dont need any sleep or stall detection)
IF it is going to drive 2 motors, it should have 9 pins =)
i am looking for simple IC because i have 15cmx15cm pcb area and need to drive 16 DC motors from 1 MCU.
Thank You.
Thank You.
