Drain Induced Barrier Lowering (DIBL) coefficient of a trans
rosaeidi
Full Member level 2
dibl coefficient
Hi
How I can measure Drain Induced Barrier Lowering (DIBL) coefficient of a transistor by simulation?
What is the range of η in subthreshold current equation?
I=Io * exp((Vgs-Vt+ηVds)/n)
dibl drain induced barrier lowering
Effectively, DIBL (drain-induced barrier lowering) leads to a reduction of threshold voltage Vt with increasing drain-source bias Vds (through modulation or reduction of the potential barrier for carrier flow from source to drain by Vds).
Therefore, coefficient "η" (describing DIBL effect) can be calculated from the measurements of Vt at different Vds voltages as: η=dVt/dVds.
Practically, this coefficient is calculated from two values of Vt: at low Vds (Vds=0.1V or 0.05V) - called Vtlin (linear part of device I-V characteristics), and at high, or nominal, Vds (Vds=Vdd) - called Vtsat (saturation part of I-V curve): η=(Vtsat-Vtlin)/(Vdd-0.1V).
