doubt in fpga terminal program
dipin
Full Member level 4
serial port demo program working.. but nothing in terminal
hi,
i am trying to do hello world program mentioned in below video..
https://www.youtube.com/watch?v=yEtVLTB4hM4
but i got a problem with rx and tx pin assignment..at 4.45 in video. i am using quartus prime 16.0. here the below mentioned pins are not assignable.
so i tried by assigning only clock, but in terminal after running program nothing is displaying. so i think its because of not assigning the pins for tx and rx. anybody know how to solve this problem ?
Signal Name FPGA Pin No. Description I/O Standard
HPS_UART_RX PIN_B25 HPS UART Receiver 3.3V
HPS_UART_TX PIN_C25 HPS UART Transmitter 3.3V
HPS_CONV_USB_n PIN_B15 Reserve 3.3V
the above one is from user manual of cyclone 5 sockit .(you can get it from google it & first result and then page 38)
so anybody know how to do it . any help is really appreciated
tthanks
Re: serial port demo program working.. but nothing in terminal
If the pins are not assignable then maybe you've got a different package than the demo references...
hi,
those pins are belong to hps..
regards
hi,
did altera cyclone 5 sx fpga will work with terminal program ( like putty, teraterm) with out booting linux from sd card?
like "hello world" program works in cyclone 2 fpga ?
trying to print hello world , didnt get a reference program with soc kit, there is two demos, one is using jtag uart and other one is booting from sd card.
thanks and regards
If
* the FPGA output is UART style
* the voltage levels and polarity is correct
* the baudrate is correct
* the transmit parameters (usually "8N1") are correct
...Then it should work
Klaus
Reactions: dipin
    dipin
As said in #2 terminal programs ( like putty, teraterm) are independent of FPGA dev boards.
If your RTL simulation is working properly, just check out the proper settings of the terminal programs.
Reactions: dipin
    dipin
Not clear what you want to achieve. JTAG UART provides a terminal interface through the Altera JTAG stack, but as far as I know, doesn't provide a virtual COM port that can be accessed by a PC terminal program.
I would expect a real UART implemented in FPGA, connected to a RS-232 driver of the eval board (or possibly throughly an USB bridge).
Secondly, how do you want to implement "Hello world"?. By a OS-less ("bare metal") SOC program? Or in pure HDL?
Reactions: dipin
    dipin
hi,
i am using nios2 processor + rs232(serial port) + onchip ram. my baud rate is 115200 in both uart and terminal. i tried ttwo terminal, putty and teraterm.
still not able to get it ..i will post my full project here .. what i done is generated qsys system and wrote a wrapper for it
module uart_top ( clk,tx,rx);
input clk;
input rx;
output tx;
	uart_qsys u0 (
		.clk_clk       (clk),       //     clk.clk
		.reset_reset_n (1'b1), //   reset.reset_n
		.rs232_0_RXD   (rx),   // rs232_0.RXD
		.rs232_0_TXD   (tx)    //        .TXD
endmodule
after that i went to eclipse and create the project and bsp files, then run it n hardware configuration. its showing download to fpga successful but nothing showing in terminal.
i got a doubt about pisnassignment, rx and tx are not able to assign in pinplannerfpgapin.JPG. so after few searching i selected 3.3 ltvvt in i/o part
can any body help me on this please
regards
regrds
I don't use Altera, so will not comment on the pin assignment correctness.
But 1 point regarding your uart_qsys u0 instiantiation.
This statement .reset_reset_n (1'b1), // reset.reset_n indicates that uart_qsys is always in non-reset state. But it might need a LOW to HIGH going transition for proper functioning. So please review the uart_qsys docu as to how the reset should actually be.
Reactions: dipin
    dipin
hi,
below is my full project.
ATTACH]139787[/ATTACH]
teraterm is recognizing my port, in tera teram i am selecting serial port which is already detected by teraterm (com 12) and then open the teramterm, then
>> setup>> serial port>> set baudrate to 115200.
this is how i doing it but it was not a success :(
so can you guys please check my project above ?
regards
hi i tried it by connecting the reset to slide switch in fpga. but when the switch is in low, the eclipse is throwing the error(during running as hardware), when i made it high eclipse is running fine but nothing on the terminal :(
regards
  • uart_top1.zip
