vhdl34
Newbie level 6
im trying to display a whole screen red however its not being possible im using 640 by 480 screen and im timing on25 mhz clock and refresh at 60 hz here unde ris my code can some one help me find the mistake
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_misc.all;
use IEEE.std_logic_unsigned.all;
entity vgatest is
port(clk :in std_logic;
hs : out std_logic;
vs : out std_logic;
red1 : out std_logic;
green2 : out std_logic;
reset : in std_logic;
blue2: out std_logic
end vgatest;
Architecture vga_arch of vgatest is
signal clkout : std_logic;
begin
process (clk)
variable counter : integer :=1 ;
variable clktemp : std_logic:= '0';
begin
if(clk'event and clk ='1') then
if(counter /= 2) then
counter := counter + 1;
clkout <= clktemp;
elsif(counter =2) then
if(clktemp = '0')then
clktemp :='1';
counter := 1 ;
elsif(clktemp = '1') then
clktemp := '0';
counter := 1;
end if;
end if;
end if;
end process;
process(clkout,reset)
variable count: integer := 0;
variable vert : std_logic_vector (8 downto 0) := "000000000";
variable horiz :std_logic_vector (9 downto 0) := "0000000000";
variable countv : integer := 0;
begin
if (reset = '1') then
count := 0;
countv := 0;
vert := "000000000";
horiz := "0000000000";
red1 <= '0';
green2<= '0';
blue2<= '0';
hs <= '0';
vs <='0';
elsif(clkout'event and clkout ='1') then
if(vert = "111011111") then
vert := "000000000" ;
end if;
count := count +1;
if( count <= 96)then
red1 <= '0';
green2<= '0';
blue2<= '0';
hs <= '0';
elsif(count>=97 and count <=144)then
hs <= '1';
red1 <= '0';
green2<= '0';
blue2<= '0';
elsif(count >= 145 and count<=784) then
horiz := horiz + "0000000001";
hs <='1';
elsif(count >=785 and count < 800) then
hs <='1';
red1 <= '0';
green2<= '0';
blue2<= '0';
elsif(count >= 800)then
countv := countv + 1;
vert := vert + "000000001";
count := 0;
end if;
if(countv < 2) then
vs <= '0';
red1 <= '0';
green2<= '0';
blue2<= '0';
elsif(countv >=2 and countv < 31 ) then
vs <='1';
red1 <= '0';
green2<= '0';
blue2<= '0';
elsif(countv >= 31 and countv < 511) then
vs <='1';
red1 <= '1';
green2<= '0';
blue2<= '0';
elsif(countv >= 511 and countv < 521) then
vs <='1';
red1 <= '0';
green2<= '0';
blue2<= '0';
elsif (countv > 521) then
countv :=0 ;
end if;
end if;
end process;
end vga_arch;
