erwin4838
Member level 1
- Joined
- Mar 4, 2012
- Messages
- 32
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Tangerang-indonesia
- Activity points
- 1,478
Dear all
i have a problem with my project RUNNING HOUR +TIMER CONTROLL
the problem is digit second in digital running hour is to late,not in one second
in this project i'm use software AvrOspII
this my source code
Please help me,thanks for u attention
this my source code
' Running Hour
' OUTPUT : LCD 2X16
$regfile = "m16def.dat"
$crystal = 16000000
Dim Jam As Word , Menit As Byte , Detik As Byte
Dim J_set As Word , M_set As Byte , D_set As Byte
Dim Menu As Byte , F_start As Byte , F_scan As Byte , F_led As Byte
Config Timer1 = Timer , Prescale = 256
Portd.0 = 1
Portd.1 = 1
Portd.2 = 1
Portd.3 = 1
Portd.4 = 1
Portd.5 = 0
Ddrd.0 = 0
Ddrd.1 = 0
Ddrd.2 = 0
Ddrd.3 = 0
Ddrd.4 = 0
Ddrd.5 = 1 ' Led
On Timer1 Interupsi_timer1
Enable Ovf1
Config Lcdpin = Pin , Db4 = Portb.3 , Db5 = Portb.4 , Db6 = Portb.5 , Db7 = Portb.6 , E = Portb.2 , Rs = Portb.1
Config Lcd = 16 * 2
Cursor Off
Cls
Lcd " Running Hour "
Lowerline
Lcd " Timer Controll "
Wait 2
Cls
Lcd "Hour :"
Lowerline
Lcd "Sett :"
Timer1 = 3035
Restart:
'------baca nilai awal timer---
Readeeprom Jam , 5
Readeeprom Menit , 7
Readeeprom Detik , 8
If Jam = &HFFFF Then Jam = 0
If Menit = &HFF Then Menit = 0
If Detik = &HFF Then Detik = 0
Locate 1 , 7
If Jam < 10 Then
Lcd "000" ; Jam ; ":"
Elseif Jam < 100 Then
Lcd "00" ; Jam ; ":"
Elseif Jam < 1000 Then
Lcd "0" ; Jam ; ":"
End If
If Menit < 10 Then
Lcd "0" ; Menit ; ":"
Else
Lcd Menit ; ":"
End If
If Detik < 10 Then
Lcd "0" ; Detik
Else
Lcd Detik
End If
'------baca nilai awal set time---
Readeeprom J_set , 1
Readeeprom M_set , 3
Readeeprom D_set , 4
If J_set = &HFFFF Then J_set = 0
If M_set = &HFF Then M_set = 0
If D_set = &HFF Then D_set = 0
Locate 2 , 7
If J_set < 10 Then
Lcd "000" ; J_set ; ":"
Elseif J_set < 100 Then
Lcd "00" ; J_set ; ":"
Elseif J_set < 1000 Then
Lcd "0" ; J_set ; ":"
End If
If M_set < 10 Then
Lcd "0" ; M_set ; ":"
Else
Lcd M_set ; ":"
End If
If D_set < 10 Then
Lcd "0" ; D_set
Else
Lcd D_set
End If
F_scan = 1
Gosub Scan_tombol
Do
Locate 1 , 7
If Jam < 10 Then
Lcd "0" ; Jam ; ":"
End If
If Menit < 10 Then
Else
Lcd Menit ; ":"
End If
If Detik < 10 Then
Lcd "0" ; Detik
Else
Lcd Detik
End If
Gosub Scan_tombol
'----control
If Jam >= J_set And Menit >= M_set And Detik >= D_set Then
'Portd.5 = 1
F_led = 1
End If
Loop
End
Scan_tombol:
Do
'UP
If Pind.0 = 0 Then
If Menu = 1 And J_set < 9999 Then
Incr J_set
Locate 2 , 7
If J_set < 10 Then
End If
Elseif Menu = 2 And M_set < 59 Then
Incr M_set
Locate 2 , 12
If M_set < 10 Then
Else
Lcd M_set ; ":"
End If
Elseif Menu = 3 And D_set < 59 Then
Incr D_set
Locate 2 , 15
If D_set < 10 Then
Lcd "0" ; D_set
Else
Lcd D_set
End If
End If
Waitms 250
'DOWN
Elseif Pind.1 = 0 Then
If Menu = 1 And J_set > 0 Then
Decr J_set
Locate 2 , 7
If J_set < 10 Then
End If
Elseif Menu = 2 And M_set > 0 Then
Decr M_set
Locate 2 , 12
If M_set < 10 Then
Else
Lcd M_set ; ":"
End If
Elseif Menu = 3 And D_set > 0 Then
Decr D_set
Locate 2 , 15
If D_set < 10 Then
Lcd "0" ; D_set
Else
Lcd D_set
End If
End If
Waitms 250
'OK
Elseif Pind.2 = 0 Then
If Menu = 0 Then
Menu = 1
Elseif Menu = 1 Then
Menu = 2
Writeeeprom J_set , 1
Elseif Menu = 2 Then
Menu = 3
Writeeeprom M_set , 3
Elseif Menu = 3 Then
Menu = 0
Writeeeprom D_set , 4
End If
Waitms 250
'START
Elseif Pind.4 = 0 And F_start = 0 Then
Start Timer1
Enable Interrupts
F_start = 1
F_scan = 0
Waitms 250
'STOP/PAUSE
Elseif Pind.4 = 1 And F_start = 1 Then
Stop Timer1
Disable Interrupts
F_start = 0
F_scan = 0
Waitms 250
'RESET
Elseif Pind.3 = 0 Then
Menu = 0
Jam = 0
Menit = 0
Detik = 0
J_set = 0
M_set = 0
D_set = 0
F_led = 0
Writeeeprom Jam , 5
Writeeeprom Menit , 7
Writeeeprom Detik , 8
Waitms 250
Goto Restart
End If
Loop Until F_scan = 0
Return
Interupsi_timer1:
Stop Timer1
Detik = Detik + 1
If Detik >= 60 Then
Menit = Menit + 1
If Menit >= 60 Then
Jam = Jam + 1
Writeeeprom Jam , 5
If Jam >= 9999 Then
Jam = 0
Menit = 0
Detik = 0
Writeeeprom Jam , 5
End If
Menit = 0
End If
Detik = 0
End If
Timer1 = 3035
Start Timer1
If F_led = 1 Then Portd.5 = Not Portd.5
Return
