kirteshmiet
Member level 1
The first of these attempts is the so-called basic OCV analysis. It relies on the fact that best- and worst-case conditions can’t occur at the same time. A single global derating factor is applied to delays to account for the fact that they will be somewhere between best and worst case in reality.
This offers some improvement but becomes too crude as dimensions shrink. The single OCV derating factor reflects some “average” path length but is over-optimistic for short paths and over-pessimistic for longer paths. The solution here has been to use a table of derating values. By specifying the length of the path and the position of the cell in question in that path, you get a derating value from the table that you can use to account for this location dependence.
This approach is generally referred to as Advanced OCV, or AOCV (which also appears to be referred to as Location-based OCV, or LOCV). It provides better accuracy and reduces pessimism on long paths (as well as reducing the chance of errors in over-optimistic short paths). Of course, it comes with a cost: these tables have to be built, and if each cell in the library has to be characterized for, say, 5 path lengths and 5 positions in that path, that’s a 25-entry table for every cell that has to be derived via SPICE.
There is a tool that can help with this: CLK Design Automation has a tool called AOCV FX that they claim reduces the time it takes to build the tables from weeks or years (theoretically… not sure there’s experimental data on that…) using multicore SPICE to minutes or days using AOCV FX.
There are variations on AOCV. The “default” derating tables assume the full slew-rate range . “Design-based analysis” determines the design-specific range of slew rates in your design in order to customize the derating table. With “instance-based analysis,” each instance of each cell gets its own value in the table based on calculated loads and skews (clearly resulting in a much larger table).
One of the benefits of AOCV is that it works in conjunction with traditional STA tools, and so it can be added to the verification methodology without much disruption. All the major STA tools can accommodate AOCV. However, there’s another approach that’s now being proposed by Extreme DA which they call Parametric OCV, or POCV.
They target their argument against two AOCV characteristics: the complexity of building the AOCV tables (which is presumably mitigated by tools) and an inherent inaccuracy in that AOCV doesn’t independently model n-channel and p-channel mis-correlation, which they say is particularly important for “half-cycle” paths, where launch of a signal from one flip-flop and capture on the next flip-flop are clocked on opposite clock edges.
POCV uses a statistical approach, but it doesn’t do a full SSTA analysis. Instead, it calculates delay variation by modeling the intrinsic cell delay and load parasitics (line resistance, line capacitance, and load capacitance) to determine both the mean and “sigma” (variation) of a logic stage. The cell delay can be further broken into an n-channel component and a p-channel component. They then assume that all the cells along a path have the same mean and sigma.
This means that a given path doesn’t have to be analyzed stage-by-stage; the number of stages can be counted, with the basic stage delay mean and sigma then used to calculate the path delay and accumulated variation. They claim that this keeps the run times down to just over what standard STA tools require, far faster than SSTA. They also claim speedier execution and greater accuracy than AOCV, and no derating tables are required.
Extreme DA provided an example showing the impact of their approach as compared to AOCV on a 1.2-million-instance design at 264 MHz with SI enabled. The focus was on hold-time fixing when optimizing across two corners and two modes. POCV’s reduced pessimism resulted in around 5,800 hold violations as compared to about 15,300 for AOCV. The number of buffers inserted to fix the violations dropped from about 15,000, or around a 1.1% area increase, to about 4,600, or about a 0.33% area increase. Run time was about 20 minutes, down from 60 minutes for AOCV.
Because POCV is statistics-based, it needs an SSTA engine in order to be used. This means it can’t slide into just any STA tool, but the POCV approach is used in Extreme DA’s GoldTime tool and has also been licensed by ATopTech. Extreme DA is open to considering other licensing requests as well.
