you don´t tell in what context...
But the names tell almost everything:
* voltage peak detector: detects the peak value of a voltage signal
* voltage RMS detector: detects the RMS (root-mean-square) value of a random signal. It represents the DC value that generates the same power on an ohmic load as your random input signal.
* power detector: P = U x I. Either it calculates the power for a specified resistance (50 Ohms) or it calculates the (avaerage) from U x I
Klaus
what is the difference between voltage peak detector, voltage rms detector and power detector? Any reference? Thanks.
A power detector will detect the voltage but will be converted to a power, using for instance a diode operating in the "square region", so that the output voltage will be Vo=Vin^2. We know that the power is given by P=V^2/R, this means the output of the detector will be proportional to the power with proportionality 1/R that can determined after a calibration. However there are other methods for RF power detectors..
