difference between cdl and sp file.
sanjaysharmaiitk
Member level 1
KANPUR
i am using calibre with innovus (encounter) .
i am geting problem in LVS
WARNING: XDB Database not available: No comparison was made
Comparison result :some are ERROR coming "port name not valid for netlisting W1.png"
Extraction result : some are WARNING coming "Power net missing in layout. Ground net missing in layout"COMPARIZON.png
how to solve these problem.
i am doing LVS for UART verilog code.
comparing spice netlist file generated from verilog file using script " l2vs" command in calibre
Note:
v2lvs -v uart_mnet.v -o uart_NOmnet.cdl -l /cad/cadence/TechLib/SCL/scl_pdk/stdlib/fs120/verilog/vcs_sim_model/tsl18fs120_scl.v -s /cad/cadence/TechLib/SCL/scl_pdk/stdlib/fs120/cdl/tsl18fs120_scl_no_supply_pins.cdl -sk -s0 VSS -s1 VDD
and compare with .gds file generated after merge cell .gds file available in pdk and .map file available in pdk.
Comparison result :some are ERROR coming "port name not valid for netlisting View attachment 140605"
Extraction result : some are WARNING coming "Power net missing in layout. Ground net missing in layout"View attachment 140606
Note:
just make sure your gate level netlist has power ports for all gates
layout verification
i used DC(Design compiler) for synthesis
after synthesis get-level netlist has been generated.
i have attached gate-level netlist of a small design
johnson counter.
i gat-level netlist no power port are defined.
how to define power port in verilog gate-level netlist ?
Note:
in layout i used rings for suppy "vdd" and "gnd".
Re: layout verification
johnson counter.
Note:
your standard cell library provider probably has another version of the library that has power pins. use that version instead.
