dft question (pls answer )
gold_2007
Member level 1
bangalore
can any one tell me what are the different information does a designer give to dft person along with the netlist and library.
Also give the clock domains, reset strategy, latches, combinatorial loops if any
    gold_2007
They will give u clock and reset.. bcoz these are the most important thing u have to consider and u have to take care about the synchronism..
Muxes, clock ,reset are the most important thing for a dft designer to choose
    gold_2007
critical path, sta scripte
    gold_2007
Hi All,
Along with the above information they will also tells the power domain info and jtag register configurations that we need's to do for the required modes and controlls..
regards,
ramesh.
    gold_2007
rameshsuthapalli said:
Hi All,
regards,
ramesh.
Thanks ramesh and all
Dear Designer
my 2 cents in this discussion
1. Verilog netlist
2. STIL/TPF file (Standard Test Information file/Test Protocol file) , a procedure file generated from the DFT test compiler report
3. List of flip-flops in each scan-chain.
4. Scan input and scan output signals
5. Scan clock name
6. Signal to control the resets.
7. Scan mode/Test mode signals
8. Flops not part of chain and any reason.
Praise the Lord.
best regards,
www.vlsichipdesign.com
[Learn ASIC Chip Concepts both frontend and backend for free]
    gold_2007
