[SOLVED] Designing Automatic Voltage Stabilizers
Re: Designing Automatic Voltage Stabilizer
There is only 4 relays. Other is LED (rc4) and it starts blinking when out of range. If you connect a relay to this pin, it will start to do "tic tic".
I change port also . as I shown in pin configuration .,
Post your code.
I think there is an error here. When input is higher than 220V. It is never connected with 260V loop.
Here C2 is shown for LED but in label, C4 is assigned for LED instead. In addition. "count" variable is never called. It is a compiler warning message.
stabilizer is not designed for high voltage .
variable is erased in this code
here is new code and hex file
/////////////////  03124002221  lahore pakistan
   #include   <16f676.h>
   #device     adc=10
   #use        delay(clock=4000000)
   #fuses      intrc_io
   #fuses      NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
/////////////////////pins  lables///////////////////
   #define     relay1   pin_a1      //main   change
   #define     relay2   pin_a2      //main   change
   #define     relay3   pin_c0      //outputchange
   #define     relay4   pin_c1      //output on off
   #define     led      pin_c2      //led for indication of timer
   #define     sw       pin_a3      //active low
   #define     low_limit      1550  // limit for low  voltage
   #define     high_limit     2450  // limit for high voltage
   #define     low_ok         2100  // value for main low  function compleate
   #define     high_ok        2440  // value for main high function compleate
   #define  on       output_high
   #define  off      output_low
   unsigned int32 main_v=1000;
   unsigned int8  step=1,time=0,x;
   int1           fault=0;
   unsigned int8  delay=30;
   void adc_read  (void);
   void relay_Set (void);
   void main_high (void);
   void main_low  (void);
   void initialize(void);
   void  start_up (void);
/////////////////////timer1 isr//////////////////////
   #int_timer1
   void  timer1_subrutine(void)
   set_timer1(65536-62500);         // after 0.5S interrupt will rise
        time++;
         output_toggle(led);
            if (((time>delay)||(input(sw)==0))  &&  (fault==0))
                  time=0;                          // for next round
                     on(led);
                        on(relay4);
                        disable_interrupts(int_timer1);
                            disable_interrupts(global);}
   void  main()
   initialize();
   WHILE(true)
       start_up();
////////////////////normal loop///////////////////////////////
   do
   for(x=0; x<20; x++)                               //loop to perform voltage stabalization function
                                                     // if gap is larg then  only one step can not stabal voltage
      adc_read();
         if(main_v>2410)
               {step--;  if(step<1)step=1; relay_set();}     //239V
                   else if(main_v<1630)                      //200V
                     {step++; if(step>6)step=6;relay_set();}
                        else;
   while((main_v<high_limit)&&(main_v>low_limit));  // check  the limits
/////////////////////under over section///////////////////////
   fault=1;
         time=0;                                          // reset timer if it was running
         if(main_v>=high_limit)         main_high();      // call  relevent function
            else if(main_v<=low_limit)     main_low();    // call  relevent function
               disable_interrupts(int_timer1);            // reset timer and interrupt
                           fault=0;
   enable_interrupts(int_timer1);
       enable_interrupts(global);
         off(relay4);
            off(relay3);
               off(relay2);
                off(relay1);
                  delay_ms(500);
                  while(main_v<low_ok)
                        time=0;
                           adc_read();
         off(relay4);
            on(relay1);
               on(relay2);
                on(relay3);
                  delay_ms(500);
                     while(main_v>= high_ok)
                         time=0;
                               adc_read();
   delay_ms(20);
      main_v =read_adc();
         main_v=main_v*5000/1023;
 void    initialize  (void)
   off(relay4);
      on(relay1);
         on(relay2);
            on(relay3);
/////////////input output setting////////////////////
   set_tris_a(0b11110001);
      set_tris_c(0b11111000);
         output_float(pin_a0);
            setup_adc(adc_clock_div_64);
               SETUP_ADC_PORTS(sAN0 ) ;
   delay_ms(100);
      adc_read();
         setup_timer_1(t1_internal | t1_div_by_8);
               set_timer1(65536-62500);                  //initialize for correct time
                  enable_interrupts(global);                //unmasked interrupts enable
  void   relay_set   (void)
if(step==1)
 { on(relay1);
   on(relay2);
   on(relay3);}
   else if(step==2)
        {on(relay1);
         on(relay2);
         off(relay3);}
      else if (step==3)
           {on(relay1);
            off(relay2);
            on(relay3);}
          else if (step==4)
               {on(relay1);
                off(relay2);
                off(relay3);}
             else if (step==5)
                  {off(relay1);
                   off(relay2);
                   on(relay3);}
                else if (step==6)
                     {off(relay1);
                      off(relay2);
                      off(relay3);}
                     else;
  • 100v stabilizer.rar
Hi Irfan
Can you explain how the relay switching works with respect to your original code? That is how the constant o/p is obtained by relay switching.
Switch at pin C3 does not seem to do anything. There is no start-up timer delay of few minutes. RLY4 is not performing this functions.
Dear Mr https://www.edaboard.com/members/493995/
please read post no 14 on this link https://www.edaboard.com/threads/213899/#post1203609 i have already explained this matter .
And lovely SIR https://www.edaboard.com/members/11764/
switch input is programmed to bypass timer if any user want to bypass timer.
read timer section.
   #int_timer1
        time++;
         output_toggle(led);
                     on(led);
                        on(relay4);
start up delay can be changed using variable named "delay".
currently it is 15 second for checking purpose.
Start up delay was not working with .hex file which I compiled but now when I used your .hex file and simulated in picsimulator, it worked properly.
do
adc_read();
if(main_v>2410)
else;
With these values output voltage should be 200 to 295 volts.
Hi,Mr irfan
i see delay value 30 for 15 second in C file.
What is value for 3 minute start up delay.
I also try to complete proteus file for your schematic and its working fine.
  • IRFAN,S_STAB.rar
Please help me to understand this line in your program:
I think a3 pin in 16f676 is Mclr pin, so how it work as sw?
(#fuses NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR)
NOMCLR means,we are using this pin as input/output instead of MCLR.
Is this stabilizer circuit correct ? In practical circuit there will be one more tapping in the TRF and it will connect to RLY5. I made this based on this circuit. https://milan.milanovic.org/skola/mikkon/mikkon-07.htm
Depending on the voltage found out using ADC the required relay is operated so that output will be 220 or 230V.
  • 16F886 stabilizer.PDF
how i change the operating voltage range of relay under the program?
      adc_read();
         if(main_v>2410)
                        else;
2410=2.410v adc
1630=1.630v adc
If you need to change these values,you should also change high and low limits.
Dear pnjbtr,
Many Many Thanks.........
Hi, Mr. irfan ahmad
I am new in programming. Please Help me to understand your program step by step. I don't understand various place in your program. Please help me. please.........
stabilizer circuit works like a selector switch.
which select transformer taping from transformer to maintain output voltage.
i have designed this selector switch in programming.
which reads output voltages and change selector switch position according to required output.
I understand the function. I just want help to understand program stepping which you write. I have another question that is this program work properly? I mean to say is it tested practically with transformer?
i have tested and it is working properly .
read the circuit diagram (specially relay connections ) carefully given in post #9 to understand programming.
