redsees
Junior Member level 1
Hello World,
I finished my first project in Verilog, which is an implementation for Simplified Data Encryption Algorithm (DES) that uses 8-bit data blocks, 10-bit key, 2 8-bit subkeys, and 2 rounds Feistel Function.
I tested the code and it works great. I just wanted from Verilog experts to review my code and give any advice they might have to improve the application (in any aspect, space or time) as this is my first Verilog project, and I want to get the maximum learning from it. Thanks in advance.
Here I'm not using any clock for synchronizing the execution, my second question is: is using a clock in every digital design I make mandatory even if my design works well without any clocks? I know it's always better to use a clock signal in order to predict outputs in different time frames, but otherwise is it a must to use it?
Here is my code:
Notes:
- I'm using 0:N-1 bit ordering because this is the famous bit ordering used in cryptography.
Here is my code:
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 /* Simplified Data Encryption Standard (S-DES) 8-bit 2-round block cipher encryption and decryption algorithm using 10-bit key. */ module SDES(input[0:9] key, input[0:7] plaintext, input encrypt, output[0:7] ciphertext); reg[0:7] tempB, tempD, IP_out, sw_out, iip_out, feistel_out; assign ciphertext = iip_out; // Generate Key1 and Key2 task GenerateKeys; input[0:9] Key; output[0:7] Key1, Key2; reg[0:9] p10_out, tempA, tempC; begin // P10 Permutations p10_out = {Key[2], Key[4], Key[1], Key[6], Key[3], Key[9], Key[0], Key[8], Key[7], Key[5]}; // Left Rotation by 1 bit tempA = {p10_out[1:4], p10_out[0], p10_out[6:9], p10_out[5]}; // P8 Permutations Key1 = {tempA[5], tempA[2], tempA[6], tempA[3], tempA[7], tempA[4], tempA[9], tempA[8]}; // Left Rotation by 3 bits tempC = {p10_out[3:4], p10_out[0:2], p10_out[8:9], p10_out[5:7]}; // P8 Permutations Key2 = {tempC[5], tempC[2], tempC[6], tempC[3], tempC[7], tempC[4], tempC[9], tempC[8]}; end endtask // Feistel Function task Feistel; input[0:7] inp_block, key; output[0:7] out_block; reg[0:3] first_chunk, second_chunk, xor_fout, xor_f1, xor_f2, p4_in, p4_out; reg[0:7] EP_out, xor_out; reg[0:1] s0_out, s1_out; begin first_chunk = inp_block[0:3]; second_chunk = inp_block[4:7]; EP_out = {second_chunk[3], second_chunk[0], second_chunk[1], second_chunk[2], second_chunk[1], second_chunk[2], second_chunk[3], second_chunk[0]}; xor_out = EP_out ^ key; xor_f1 = xor_out[0:3]; xor_f2 = xor_out[4:7]; S0_Box(xor_f1, s0_out); S1_Box(xor_f2, s1_out); p4_in = {s0_out, s1_out}; p4_out = {p4_in[1],p4_in[3],p4_in[2],p4_in[0]}; xor_fout = p4_out ^ first_chunk; out_block = {xor_fout, second_chunk}; end endtask // S0 Box task S0_Box; input[0:3] inp_bits; output[0:1] out_bits; begin case(inp_bits) 4'b0000: out_bits = 2'b01; 4'b0001: out_bits = 2'b11; 4'b0010: out_bits = 2'b00; 4'b0011: out_bits = 2'b10; 4'b0100: out_bits = 2'b11; 4'b0101: out_bits = 2'b01; 4'b0110: out_bits = 2'b10; 4'b0111: out_bits = 2'b00; 4'b1000: out_bits = 2'b00; 4'b1001: out_bits = 2'b11; 4'b1010: out_bits = 2'b10; 4'b1011: out_bits = 2'b01; 4'b1100: out_bits = 2'b01; 4'b1101: out_bits = 2'b11; 4'b1110: out_bits = 2'b11; 4'b1111: out_bits = 2'b10; endcase end endtask // S1 Box task S1_Box; input[0:3] inp_bits; output[0:1] out_bits; begin case(inp_bits) 4'b0000: out_bits = 2'b00; 4'b0001: out_bits = 2'b10; 4'b0010: out_bits = 2'b01; 4'b0011: out_bits = 2'b00; 4'b0100: out_bits = 2'b10; 4'b0101: out_bits = 2'b01; 4'b0110: out_bits = 2'b11; 4'b0111: out_bits = 2'b11; 4'b1000: out_bits = 2'b11; 4'b1001: out_bits = 2'b10; 4'b1010: out_bits = 2'b00; 4'b1011: out_bits = 2'b01; 4'b1100: out_bits = 2'b01; 4'b1101: out_bits = 2'b00; 4'b1110: out_bits = 2'b00; 4'b1111: out_bits = 2'b11; endcase end endtask always@(plaintext or key or encrypt) begin // Generate Key1 and Key2 GenerateKeys(key, tempB, tempD); // Initial Permutation IP_out = {plaintext[1], plaintext[5], plaintext[2], plaintext[0], plaintext[3], plaintext[7], plaintext[4], plaintext[6]}; // First Round if(encrypt) Feistel(IP_out, tempB, feistel_out); else Feistel(IP_out, tempD, feistel_out); // Swapping sw_out = {feistel_out[4:7], feistel_out[0:3]}; // Second Round if(encrypt) Feistel(sw_out, tempD, feistel_out); else Feistel(sw_out, tempB, feistel_out); // Inverse Initial Permutation iip_out = {feistel_out[3], feistel_out[0], feistel_out[2], feistel_out[4], feistel_out[6], feistel_out[1], feistel_out[7], feistel_out[5]}; end endmodule
Notes:
