baby_1
Advanced Member level 1
Design oscillator with linear small S parameters
Hello
I have a question about design oscillator with linear small S parameters.If you assume I use a Common emitter configuration and put my resonator at input port (Base/Emitter). After I select a Gama(G) in unstable region in input smith chart plane(for example Gama(G)=A<B (for example A=1)) and I map it into Gama(L) plane it is necessary that Gama(L) should be in unstable output region or only |Gama(L)| should be more than unity?
what is the best design ( |Gama(L)|>1 and be in unstable region or |Gama(L)|>1 and be in stable region )?
Thanks
Hello
Thanks
