DC level shifter or clamper circuit
tamil_yes
Junior Member level 1
clamper circuit
i need DC level shifter thats clamper cicuit
in that i will give +2V to -2V as input and i have to get 0V to +4V
some of my friends r telling that dont use capacitor in ur design it will create more problem
please help me
dc level shift
lov, lov, lov that app!
dc level shifter circuit
Since the applicatgion is limited to 0 to 4 volt o/p and 2 to -2 volt input an OPAMP can conveniently be used. Put a +2 volt supply to the non-inverting amplifier and the input to the inverting amplifier through a 1k resistor. In the feedbac path use a same 1k resistor.
Depending on your curent requirement and load pecification you may need a buffer at the output of the circuit.
    tamil_yes
thank u i got output
