oAwad
Full Member level 2
Hello all,
I have a pretty large design that fails DC Convergence in HSIM, the only warnings I get are the following:
But all these 10 nodes are the output ports so it's logical to have one connection, also the input ports don't cause a problem since they're connected to the vector file....so why HSIM give these warnings while I'm including these nodes as top level ports ? Should I explicitly define them as outputs in the setup file, if yes then how ?
Warning: node "KEY_READY_O" has only 1 connection
Warning: node "DATA_O[4]" has only 1 connection
Warning: node "DATA_O[1]" has only 1 connection
Warning: node "DATA_O[0]" has only 1 connection
Warning: node "DATA_O[2]" has only 1 connection
Warning: node "DATA_O[3]" has only 1 connection
Warning: node "DATA_O[5]" has only 1 connection
Warning: node "DATA_O[6]" has only 1 connection
Warning: node "DATA_O[7]" has only 1 connection
Warning: node "VALID_O" has only 1 connection
Warning: 10 nodes with connectivity problems are reported in 'hsim.conn'
DC initialization ended after 250 iterations without convergence
