sharkies
Member level 5
When designing a current-steering DAC, your load is usually a 50Ohm load.
If you look at slide6 of the attached PPT slide(by Baker), this particular design uses a current mirror load instead of the resistor.
Does anybody have more reference on this method? I found the original paper for the ppt slide, but it doesn't give any further details.
I have a feeling that there must be DAC designs out there with current mirror loads instead of the normal resistor load, but I'm not able to find one yet.
Please let me know. Thank you
