flyingoven
Newbie level 6
Hi! Everyone!
After I simulated, I want to remove higher mode from ports by Exclude port mode in Post Processing,then exported S parameters. But CST appeared message:
Export S parameters data failed.
My model is APC-7 coax air transmission line, and the middle part is Teflon.
What is the problem? Thanks.
All calculated S-Parameters are set to be excluded from post processing.
Error while running S-parameter post processing.
Error in TOUCHSTONE export initialization. No S-Parameter data found.
