storyee
Junior Member level 1
Hi all,
I am creating ideal Parameterized comparator cell, which has parameters of voltage gain, positive supply, negative supply, However, After create the symbol for the comparator, when I instance that comparator to a new schematics, when I assign a value to the positive supply area, the voltage unit can not auto-generate, is there a way to auto-generate the voltage unit "V"? is that means cadence wont consider " positive supply" as voltage parameter? thanks for any help.
