corner simulation in Spectre
fanshuo
Full Member level 5
Netherlands
corner simulation
where can I find detailed setup of the corner simulation in spectre?
Thx!
ade corner simulation
Hi fanshuo,
the simulator corner libs normally are supplied by the provider or fab which provides the design kit - mostly together with the sim. models' lib(s). Herein, only the process corners are defined, of course. The voltage & temperature corners depend on your application and will be defined in your sim. setUp.
HTH, erikl.
Reactions: scr77
    scr77
simulate process corners in spectre
I have more than 200 different corner combinations
I need to set them by hand?
spectre corner simulation
Sure. In the Virtuoso ADE window menu select Setup -> Model Libraries ...
and insert the model/corner files of your choice. For an individual corner simulation,
disable the unused files (#), s. picture below.
what is corner simulation
Your snapshot can only give one corner simulation result once. Spectre provides a particular corner analyse tool. See cadence helps.
created a .pcf corners file
thanks for files!
Added after 7 minutes:
what is the files?
Reactions: ctc
    ctc
tools cornrs spectre simulation
you can create a pcf file including all kinds of corners you want,also you can define supply voltage as a variable
for details,refer to cds help docs
how to specify process corner in spectre
what if you have more than a hundred of different combinations?It is better write a ocean program for it, I think
Is there any example for this?
