[General] Controlling brightness of a 220v-AC bulb using microcontroller
91divine
Junior Member level 3
Netherlands
Hello, I have to control the light intensity of a bulb or tube light from the analog output or PWM signal from micro-controller.
This is a part of my project in which i am making autonomous system for house.
You might run into problems trying to dim a flourescent tube light but you should research phase control dimmers for more information. You can use PWM but only if you are very careful to use the same PWM rate and phase as the AC power, a triac and standard phase control solution would be far simpler to build.
Brian.
I want to control either of one. Can you tell me which one is simpler to control and detailed how to control it.
bulbs are much much easier. as betwixt indicated controlling a fluorescent tube light is rather difficult which is why you rarely see such circuits.
there should be 'hundreds' of light dimmer/pwm/uC circuits abound on the internet..............perhaps you could find a few which are applicable and then ask for comments.
